1980 TIM RICHMOND 1980 Rookie indycar Finished...3-17-19
Started by Gary Davis, September 01, 2018, 01:38:45 PM
Thank you Bob for the look-in and comment.When I started this build I really didn't know how much fab work it was going to take. It kinda surprised me. LOL I love fab work as it challenges me to do better on each build.
Here's an update.... Both side panels are finished. The fuel buckeye slot on the left panel was fabbed. Both radiator slots were also cut in. The radiators( from the pc6 kit) were also reconfigured and added. The front part of the body panel was pinned so it wold go back in place exactly the same place every time. The top part of the engine cowl was also Fabbed and the whole for the POP OFF valve was cut in( it's off a hair and needs to be fixed...soon..) plus the base for the pop off valve was made for the intake plenium. The head rest and rollbar panel were fabbed and need to be touched up a little.. It's coming together a little at time. Primer is on the horizon!! Thanks for stopping in and commenting folks...
New engine cowl and fuel buckeye slot...
Radiators and Intake plenum..headrest ...rollbar ...
with the side panels on...
Wow!!
GREAT Fab work, Gary!!
just one question though....
What's the pepper for?  lol  ::) ;D
Thanks Ed... the pepper can is for used Xacto and Razor blades.
Thanks, Gary....
Just knew it had to have a purpose..... :)
Quote from: David Bogard on October 10, 2018, 08:35:28 AM
A lot of nice work here Gary. And yes, good reminder on the blades. If you're not going through a half dozen blades on even the most mundane build, then you're making it harder on yourself than you should!
Thanks for the compliment David.   That's for sure on the Blades. I use three different type of cutting blades. Scalpel..(for Decals)..Xacto and single edge razor blade for all other cutting. I've also taken a single edge razor blade and broke it at an angle so it would fit in the Xacto handle for  small hard to get at areas. Those things get dull pretty fast but for a specialty cutter...it works good.
David Bogard said
QuoteAnd yes, good reminder on the blades. If you're not going through a half dozen blades on even the most mundane build, then you're making it harder on yourself than you should!
Found that out the hard way back in the '70's,,,,still have a very faint scar on the tip of my left middle finger where an X-Acto  knife tip caught that finger when working with an old blade slipped off where i was trying to trim something and caught that finger tip. Talk about seeing stars like those cartoon characters do, Whatever i was working went flying across the room. Still think i hit a nerve as that area around the cut has been numb ever since. Not to mention how long it took to stop the bleeding. No....did not go to emergency or Dr.'s office.
Started on the engine area and had to come up with a way to attach the headers from the block to the turbo. I cut off the turbo housing and pinned it so it was removable. I then pinned the connecting tube(??) ends that attach to the ends of the headers. This way the whole thing will come apart (for paint) and make it a whole lot easier to assemble once everything is painted. The POP Valve was also fabbed and is in. Here are a few Progress pics...
Hey Ed...yes...more fab work is on it's way....
This update is on the coil over shocks on the rear suspension. I almost went with the molded on coils and shocks... but after removing the mold seams and pin marks I decided that they were going to be a pain in the paint brush to paint the springs and the shocks. Sooo..I decided to make the coil overs out of tube and rod from evergreen. The coil is .030 soft leader wire that I picked up at Cabella's. I made them so that they will come apart for easier painting....
Kit shocks...
Removed them here...
Coil springs....
New shocks and springs together...
Oh, yeah....!!
Wish i had the patience to try this.....
Here's a progress post. The engine is painted using ALL ALCLAD metal paints and in MOCKUP to see how things will fit together after paint. I'm happy with the snug fits. I still have clean-up and also touch-up painting to do but it's getting there. I wanted to shoot the white on the body today but it needs a few spots touched up on the body work. Here's a few engine shots...
Here are a few shots of the wheels that I shot with ALSA MIRROR CHROME. I like this paint and it's fairly easy to work with.
It dries fast and is pretty durable. It is a little on the spendy side but to me...it was worth it.
Looking fantastic Gary. Engine and wheels look great.
I can't wait to see this one finished.
Oh, yeah!!!
Engine and wheels/tires look great!!
Thanks for stopping in and commenting Bob and Ed. I still have to do the lettering on the tires to finish them. Of course....there are still a few small things like the ignition wires and smaller parts to add to the engine... It's starting to come together....
