(FINAL UPDATE 10/19) Harry Fletcher 66 driven by Johnny Grum 1967 thru 69
Started by Bob P., August 29, 2019, 09:59:47 AM
Reply to Davids question about the aluminum sheets used in a lot of my builds.
The aluminum sheets are used in the newspaper printing industries.
I have a friend, I met at a model club meeting, that works for a newspaper printer.
At one of our meeting, he brought ten or fifteen sheets and gave some to anyone who wanted a sheet or two.
Most members were not interested in using aluminum for building.
The sheet size is 23" X 10 1/2"
The thickness is .2 MM or 1/128 of an inch thick.
The sheets are grey on one side and shinny aluminum on the other side.
The shinny side looks just like a sprint car wing, raw aluminum unpainted.
I probably use it a little too much on my builds, but it's nice to bend and holds it shape.
Very cool project, Bob, and neat fab work!!!🤗🏁🏁🏁
When scratchbuuilding all materials are acceptable in my book, especially when the materials are free!!!
Another small update
I finished making the tail tank, also aluminum.
I did the cut outs on the side panels and formed the rounded area at the rear.
Then made a fixture out of a block of wood.
Next get the two sides aligned and clamp them tight.
Bend the top area of the tail tank to match the sides.
Put CA glue on the top edges of the side panels and attach the top panel, hold in place and spray some quick set to lock in in place.
Then the seam on the inside gets build up with thin layers of CA glue, then apply baking soda on each layer, dries immediately. this makes a very strong joint.
The top panel overhangs the sides. I sand it down close with my small belt sander, then finish with file and sanding blocks.
Thanks for following along and for the nice comments.
Thanks again guys for all the nice comments on this build.
More updates soon.
Check out the driver Johnny Grum in this picture.
He had to wear an arm guard, his right arm would rub the right rear tire.
Another update:  All body panels fabricated and ready for paint.. I still need to finish the top wing.
Front screen material provided by John 2 on the forum.
Can't wait to see this one done! Just gotta go find my drool bucket again.
Man, Bob, your metalwork it gorgeous and I'm in awe of how beautiful this car is even without color on it!!!🏁
This is sure looking GOOD Bob. I can just smell the Methanol as I walk by in the pits. This is going to REALLY look good with the paint on it....
FINAL UPDATE, prior to completion.
Thanks again for your interest and comments on this build.
All body panels complete and painted. Top wing still needs blue paint on side panels.
Parts just set in place for pictures. Rear bumper needs completed after decals are applied to tail tank.
Greg Holland is doing his magic on another set of decals for this build.
Next post will be the finished build.
Even if your not posting pictures to the forum, it's good to take several pictures and look at them.
I can clearly see on the pictures the wing is setting too high above the roof, simple fix to shorten the mounting pins.
Man....I knew it would look good!! That just looks COOL as hell!!! Again....great work Bob...
