Problems logging on
Started by Fordguy01, January 20, 2021, 10:38:06 PM
I mentioned this once before that I was having problems logging on.  When I try I get a message stating that "I am not authorized on here and that there is an error code of 403".  When I mentioned it before I was able for a short time to continue logging on but than it stopped.  I also tried reentering my password and username to no avail and finally this evening I was able to back door the site and get in.  I am wondering if the server change had anything to do with the issue.  I need help and hopefully someone can help me.  Thank you for your help.
Seeing as I am a computer klutz, I am no help at all here.  So, I think a pm to Tom would be good.  That is -- if you can get back on.
EVERY time I try to log in, I get rejected and put the same info in a 2nd time and it is accepted..........
Try clearing your cache.  Also try logging completely out, then type in user name and password to see if that helps. If you're using any auto fill data since the server switch I think you may need to do that. Thats about all I have.
Tb
