Krylon metallic paint
Started by Maineboy, July 22, 2021, 07:53:22 PM
Maineboy
I got a can of this, in blue,  to use on my 56 Chevy project. No matter what I do the"metallic" part shows up in the finished paint much more than I like.  I have warmed the paint, agitated the can for serval minutes and still the same. The finish I get looks like it has sizable metallic pieces in it that show right up in bright light or sunlight. I am kind of disappointed as the color is just what I wanted. Anyone else had this kind of trouble? Any ideas on how to make it work better?
MB
Did you prime the body first? A dark primer might help? But that might alter the blue a little as well. Try using several light coats, but I'm not confident you can do much about the actual metallic. I use Tamiya paints. The metallic is very fine in their paints. Much more to scale.
Tb
Maineboy
I bought this paint because it was the color I wanted for the car. I applied it over flat black primer. The color in it is OK but the metallic stands out too much. I used Tamyia lt blue with metallic and  that came out nice. Guess I shoulod not use cheap paint.
MB
Scale metallic only comes in scale hobby paints and even then the flakes can be too big at times. Glad you got it worked out!
Maineboy
Thanks for the responses.   I sprayed the paint on a larger flat plastic surface and it looks lots better on that. I painted some wheels with it before I experimented on something else and now have to take the paint off of them. I agree, the metal particles are too big for this to be used on something as small as a model car. The metal flakes tend to be way over obvious on small multi curved surfaces. I was blinded by the color shown on the cap of the can and thought of little else. Think I have found another paint, non-metallic that is very close to the same color. Sprayed that on a flat piece of plastic yesterday and like that much better.
Back to car building when I get the time. This year is crazy, adverse weather conditions in Maine have  messed up our hay mowing operations. Never know what I am going to be doing from one day to the next. Winter is better time for model building as I have way more spare time with darkness settling in at 4 instead of 9 at night. Don't get any evening time to work on the models this time of year.
Agree on the time aspect. Just got back from about 10 days in Georgia to see my youngest daughter and my four grandchildren. I could not prepare much beforehand because of some work projects so now that I am back, I'm w-a-y behind at work/ with my own grass mowing and spraying/ with my mother's house and that mowing and spraying/ and so on. Time never seems to be on my side these days.
