New Items From Ron Coon Resins
Started by RCR, November 20, 2022, 01:31:40 PM
RCR
RON COON RESINS
New Item Announcements
11/20/22
Ron Coon Resins is proud announce the release of four new items to be added to our lineup of premium circle track parts, the FT_4, SH_3, HS_AD3, and DC_AD2.
Here at Ron Coon Resins we realize not all our customers are competition builders with a competition budget, that is why we developed the FT_4 filler tank. Get a great looking deck mounted rear end filler tank at a fraction of the cost of our FT_2 competition tank. Designed and 3D resin printed by Ron Coon Resins.  Overall dimensions are height = 9.38mm and diameter = 5.8mm. Can be found in the "Miscellaneous Parts" section.
The SH_3 is something our Street Stock, Hobby Stock, and B Mod builders have been asking for and I think we have delivered in a big way. The SH_3 is a TCI style automatic transmission shifter that would be a great addition to your build especially if you are using our TR_PG Powerglide transmission! Can be found in the "Driver's Compartment" section.
Up next is an absolutely awesome item designed and 3D printed by Jim's Outlaws exclusively for RCR, the HS_AD3. The HS_AD3 is a Renegade style air cleaner air deflector that will take your next build to a whole new level. Seen on many top touring Late Models the HS_AD3 will definitely get the attention of other builders! Overall dimensions are width = 21.4mm, length = 20.3mm, and height = 4mm. Can be found in the "Body" section.
Last but not least is another designed and 3D resin printed by Ron Coon Resins item with our Street Stock and Hobby Stock builders in mind, the DC_AD2. The DC_AD2 is a driver's air deflector that adds that extra detail at a budget price. Overall dimensions are height = 5.5mm. length = 14.3mm, and width = 16.5mm. Can be found in the "Driver's Compartment" section.
All items are in stock and on the website.
Thanks,
Ron Coon
Ron Coon Resins
www.roncoon.com
