Saws
Started by Dirtman, November 06, 2023, 02:51:50 PM
What kind of saws does everyone use. If I'm chopping a top, how can I get a good clean line?
I've got a couple of Xacto saws and a saw attachment for my Dremel. One is a little thinner than the other. Work well for me, but I've never chopped a top. I wouldn't even attempt it with the Dremel.
Thanks man, appreciate the help.
I have a few different sizes of the X-Acto razor saws. They work pretty well for me.  Before I start a cut I will drag the flat edge of the blade across a candle, seems to make it cut better.
Speedracer
Scale Motorsports has small saw blades that fit into the Xacto #11 blade handle. They are #1102 in their online catalog at scalemotorsport.com
"It's hard to throw stones when you're washing feet"
...For straight lines I use a fine tooth Zona saw...less filler putty needed.  For curved lines, I use what looks like a stainless steel scribing pencil with a very sharp point...I'm able to apply as much pressure as needed with not much of a gap afterwards...its diameter is slightly more than a pencil
Hey! Thanks guy. A few things I can go!!!!
