Painting tires
Started by jh63fan, February 15, 2025, 08:01:41 PM
I never have messed with 3D printed or resin tires before, until now. What do you paint them with color wise and brand. I intend to use decals for the lettering.   Thanks
Speedracer
I use Rustoleum 2X flat black primer without any issues
"It's hard to throw stones when you're washing feet"
Spooker
I've had good success with Tamiya Rubber Black.
Quote from: Spooker on February 16, 2025, 08:57:18 AMI've had good success with Tamiya Rubber Black.
Does the Tamiya rubber black come in a spray can? I don't have an air brush.
Yes, it comes in a spray can Tamiya 85082 TS-82 Rubber Black Lacquer Spray Paint 100ml
Quote from: Brian Conn on February 16, 2025, 01:51:44 PMYes, it comes in a spray can Tamiya 85082 TS-82 Rubber Black Lacquer Spray Paint 100ml
Thanks Brian 👍
...I have been using rubber Black brushed on tires from a bottle as well as on engine belts and hoses with great results.  I first apply a thin coat of a either matte or flat Black then the rubber Black.  It can also be used to  high light the rubber strips found on doors, trunk lids and window seals if visible on the build.
