The #25 Race Team outside shots....3-15-2018
Started by Gary Davis, February 05, 2018, 03:42:27 PM
Charlie.D
Where did the camper come from. Or is it scratch build camper
Charlie Daniel
Quote from: David Bogard on March 21, 2018, 06:21:26 PM
What do you use the electric toothbrushes for? Maybe polishing? They're either a true modeling trick or you have the best looking teeth in town!  ;D
The tooth brushes are used for sanding. I save the heads from my reg. toothbrush and cut the bristles off and then shape the tip to what I need. I then cut a double sided(sticky both sides)thin foam pad onto the new shaped head...trim to the shape and then attach the grit of sand paper that I want. It works great.
Quote from: Charlie.D on March 22, 2018, 12:04:18 PM
The Camper is completely fabbed from plans that I drew up. I used Evergreen  Plastic shapes and sheet for the material. The rear bumper was completely scratch built using Diamond plate from Don Mills and shot with the air brush with ALSA Mirror Chrome.
Hey David...I'm using the Phillips Sonicare e-series tooth brush. That's for my teeth and for the model sander( NOT the same handle for the teeth...LOL). So...it works out pretty good for replacement heads for the sander. Right now I've got plenty of heads in the storage box.  The cheapest place I found to get one of those Brushes is at Target. I think thet're around $60.00. That's cheaper than Micro Marks electric model sander.  I get the head refills at Walmart. They come in sets of three for around $20.00 some dollars. The double sided sticky Foam I found at Michael's Craft store.
TLouis
Thanks for the look-in and compliment Slimster! Good to see ya posting...
